Quick question about switching to carb
Car: 1983 Z28
Engine: 6.6L 406
yup i did it in my camaro and i just tossed the comp the other day.
LONG LIVE THE MUSCLE CAR!!!!! MAY ITS REIGN NEVER END
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, flowtech shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust systemm, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, B&M shifter, dakota digital gauge package, procharger supercharger.
future mods:
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
A few things changed between 1983 and 1991. Leave the ECM in there, take out the SES light bulb. Disconnect/tie back the harness pieces that aren't being used by the carb setup, leave everything else alone.
How are you handling the fuel pump?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Well we're swapping in a whole new 350. Were getting a new fuel pump for the carb setup. The main reason im asking if i can toss the ecm, is because my ecm might be fried. And im hoping that it wont be an issue with the new engine and carb setup.
Hey super83, just curious, what kind of gas mileage do you get with your setup?
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i swapped my motor out in my 86 camaro. got a fresh 360 with a holly 700 double pumper on it. you can toss the comp and all the wires connected to it. you just need the red and pink (mine was pink) wires out the drivers side. thats the ignition. i dont know what your doing for a fan or pump, i just got all electric and wired it all in with a switch for the fan and i wired the pump to the ignition. i went with the complete MSD setup (box,dist,and coil with wires) as long as you got 12 volts to the motor your all set. just wait till you have to install the pump, hard finding spots under there. ive also heard that with a 700 tranny, if you dont get the right throttle bracket you can ruin the tranny. something to do with the kickdown cable or TV cable, not really sure.
86IROC112
08-17-2015 02:00 PM
