Engine runs after turned off... WTF??!?
Old Mar 12, 2002 | 09:46 AM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
Hey guys... so i ran a couple errands this morning in my 85 T/A, pulled into a parking spot and turned the car off, pulled the key out of the ignition... It sputtered once or twice and then died, i'm like "Wait, the key was in my hand, what was that?" So i didn't really think much of it... Tried to start it, needed to give it a little bit of gas. (carbeurated)
So i pull into another spot, turn the car off, take the key out, and it sputters repetatively, as if the fuel had been shut off but there was still spark... it lasted so long i had time to put the key back into the ignition, depress the clutch and turn it to the "on" position--- At which point it caught and began running normally again.
I turned the car on and off a few more times, but it didn't do it again.
So my question to you guys is WTF is going on???? haha.
Old Mar 12, 2002 | 09:57 AM
84Camaro305's Avatar
Car: 1989 Pontiac Firebird
Could be that you're idling too high. My car was doing that when I had the idle set higher because it wasn't wanting to stay running for some reason. Once I turned the idle screw a few times, it shut off normally.
Old Mar 12, 2002 | 10:12 AM
TransAm's Avatar
Ok. Do you think this may have something to do with outside temperature aswell??? I've been running the car in cold Massachusetts for the past few weeks-- Just brought it down to sunny humid Florida. Think that the extra heat & humidity is making the previously correct idle too high now??
Old Mar 12, 2002 | 10:26 AM
Could be because I had to correct mine for a week or two of some cold weather we had here (north texas). After the weather got better and temperatures rose, it started the problem that you have. Just lower the idle some and it should fix your problem.
Old Mar 12, 2002 | 11:53 AM
jdrobley's Avatar
you have what is known as 'deiseling'. this basically means that your engine is hot enough to detanate gas or oil from blow by and continue to run on it's own without spark. check your timing ( determines when and how much combustion pressure you have when you turn your car off) and let your car idle for 5 sec when you get somewhere.
jess
Old Mar 12, 2002 | 12:41 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
jess
True, If your running a fair amount of advance and quality of your fuel is poor this will happen. Dump some water remover/ fuel line antifreeze in the tank and see if it helps, next time get your fuel from another source or get a higher octaine. You could also cure this by dropping the timing down a couple *.
Old Mar 12, 2002 | 02:03 PM
Chevy83Z28's Avatar
try kicking the engine down before you shut it off, this will also sometimes help to drop the idle before you shut it off. just look at the tach before you shut it off.. on my car it will usually shut off anywhere around 600 and lower rpm w/o running on
Old Mar 12, 2002 | 03:19 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
My car did that too, I just swapped out the diesel for a gasoline engine.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
