GARAGE, THIRDGEN, SBC, BBC, FOURTHGEN CLEAN OUT ALL MUST GO MAKE OFFERS
Old Nov 27, 2010 | 04:59 PM
Camaro2you's Avatar
Car: Camaro
ALL ITEMS ARE OBO. ALL ITEMS ARE IN TURNERSVILLE NJ 08012-1902 WILL SHIP ALL ITEMS OR WILL BE ABLE TO DELIVER. CONTACT ME VIA EMAIL OR BY PHONE 856-889-5763, THANKS.
Have pictures of all the items give me an email address and I can send you pictures.
6" porter cable 7424 polisher with extended cord $75
Devilbiss StartingLine spray gun kit $25
Canton Racing BBC oil pan with pickup tube $125
Covan 82-92 Camaro Gauge panel with Phantom gauges and wiring $700
Gen I SBC vortec balancer $20
SBC BBC power master mini starter $65
82-92 Camaro black center console bottom and top $65
82-02 1.5" rear lowering springs red $25
82-92 camaro/firebird NEW OER hood hinges $45
Painless 18 circuit wiring harness with gm column plug 10201 $250
82-92 camaro black door panels with new upper trim $125
Dynamat 11101 $25 each have two
93-02 A4 shifter $10
GM rectangle master cylinder cover NEW $5
93-02 camaro ebony DS dash vent $5
93-02 camaro ebony PS dash vent $5
93-02 camaro lighted rear view mirror $5
82-92 camaro turn signal lever with delay wipers $20 each have two
93-02 gray hatch area speaker grill $5
82-92 camaro/firebird BMR front spring perch for use with tubular k member $40
93-02 hatch pop button $5
Billet valve cover breather for use with vacuum pump $5
93-02 camaro hvac controls $10
Comp cams BBC billet two piece timing chain cover $150
82-92 camaro/firebird black NEW sunvisors $50
Wilwood 260-8556-p master cylinder NEW $120
82-92 camaro GM horn button NEW $35
MSD HVC II coil 8261 NEW $75
82-92 camaro/firebird front door glass seal NEW $20
82-92 camaro/firebird hood to cowl seal NEW $15
82-92 camaro/firebird antenna mast bezel and nut NEW $10
82-92 camaro/firebird hood safety latch NEW $10
82-92 camaro/firebird hatch latch manual with key $10
82-92 camaro/firebird gas pedal $5
82-89 camaro fog light switch and panel $5
82-89 camaro cig lighter and panel $5
82-89 camaro dash vents $5
82-92 camaro/firebird brake pedal pad $5
82-92 camaro/firebird rear view mirror $5
1050 Holley Dominator with perceys adjustajet and spring return bracket $850
C5 corvette wheel tire pressure sensors $80 each have four
8.1 L K&N cold air intake Avalanche Yukon Tahoe Suburban ETC $180
BBC 427 SFI B&M flex plate $40
93-02 camaro/firebird ttops $150 for the set
82-92 camaro tail lights pristine condition $50 for the set
82-92 camaro armrests black pristine condition $35 for the set
82-92 camaro steering wheel NEW $70
82-92 camaro headlight support panel $20
82-89 camaro front gfx GM NEW $250
Police/Firefighter light wig wag controller with wiring $20
Old Nov 27, 2010 | 05:09 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: GARAGE, THIRDGEN, SBC, BBC, FOURTHGEN CLEAN OUT ALL MUST GO MAKE OFFERS
What's included in the Devilbiss StartingLine spray gun kit ?
Old Nov 27, 2010 | 05:23 PM
Camaro2you's Avatar
Car: Camaro
Full size gun, small touch up gun and cleaning tools.
Old Nov 27, 2010 | 06:31 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
Got pics of the 82-92 fog lights? Jer4251@hotmail.com
thanks
Old Nov 27, 2010 | 09:49 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
email sent on the following:
- 82-92 camaro hatch pop buttom white NEW $5
- 82-92 camaro/firebird door handles black NEW GM $15 each have two
- 82-92 camaro/firebird front door glass seal NEW $20
- 82-92 camaro outter window seal/felt NEW $40
Old Nov 27, 2010 | 09:58 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
can i get pics of the:
heres my email chevy0013@aol.com
Old Nov 28, 2010 | 10:55 PM
Car: 1983 Z-28
Engine: 5.7 L
do u still have the starter?...wats the lowest u will take shipped to 90650?...
Old Nov 29, 2010 | 11:59 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Pics and shipping quote for the dash pad to 63362? Thanks.
Old Nov 29, 2010 | 12:19 PM
PTS's Avatar
PTS
Car: 89 Vert Camaro
Engine: 3.8SFI Turbo
Transmission: 200R4
What brand?
Old Nov 29, 2010 | 04:30 PM
dead sailor's Avatar
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
Please email pics to guitarpick1992@aol.com
-battery relocation bracket
-black center console
-black door panels
-black armrests
Old Nov 29, 2010 | 04:47 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
what style are the front gfx please?
Jon
Old Nov 29, 2010 | 04:48 PM
Camaro2you's Avatar
Car: Camaro
Jon
85-89
Old Nov 29, 2010 | 10:13 PM
1HotZ28&SS's Avatar
Car: '11 Explorer Limited
Hi, I may be interested in your steering wheel. Is it really in great condition, it would be going on a show car. Do you have any pics?
Old Nov 30, 2010 | 07:55 PM
mullery's Avatar
Car: 1989 Black IROC-Z
Engine: 305 with G92 option
Transmission: T5 5-speed manual
Axle/Gears: Borg Warner 9-bolt, 3.45 ratio
Hi, I am interested in the steering wheel and dash pad. Please send pics and a shipping quote to ship to 34685. mullery@me.com
Thanks.
Old Nov 30, 2010 | 09:25 PM
claytonjn's Avatar
Car: '92 Camaro Vert
Engine: 305 TBI V8
I'm interested in the following, can you send pics to JamMasterClay@gmail.com
Thanks!
Originally Posted by Camaro2you
Z28 Lloyd Mats z28 embroidered on the fronts less then a year old $125
BMR Battery Relocation kit new $70
82-92 camaro hood pop cable NEW but used a few times $20
Old Dec 1, 2010 | 04:15 PM
1meanbird's Avatar
Want a title? Post!
Car: 87 formula
Engine: 355 c.i
Axle/Gears: strange posi 3.42
DO YOU HAVE A PART# FOR BBR BATTERY RELOCATE KIT??
Old Dec 1, 2010 | 05:53 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
I take the spraygun kit !!!!
Old Dec 1, 2010 | 06:28 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Pic of taillights & Bigblock 2piece timing cover
hinton_robertwilliam@yahoo.com
Please
Old Dec 3, 2010 | 10:31 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Email pics here
Old Dec 4, 2010 | 11:20 AM
Camaro2you's Avatar
Car: Camaro
There are only two kits on bmr's site one is black one is red.
Old Dec 6, 2010 | 06:54 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
One week without a response from my original request.
Old Dec 6, 2010 | 07:06 AM
jokertwink's Avatar
Car: 91 Camaro RS
Engine: 305tbi in process swamp 96 LT1
still got sunvisors? send me pic pls..
Old Dec 7, 2010 | 11:18 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Thanks for the reply. Money sent.
Old Dec 8, 2010 | 12:10 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Axle/Gears: Zexel Torsen 3.73, 28-spline mosers
I didn't see it, maybe I missed it. Do you have the power antenna for this? Or was it a static antenn?
Old Dec 8, 2010 | 12:27 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
any pictures of the gauges?
Old Dec 17, 2010 | 07:02 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
FYI, it's been 10 days since I sent him money and I haven't received my item, nor have I received a tracking number.
Old Dec 17, 2010 | 07:30 AM
claytonjn's Avatar
Engine: 305 TBI V8
It had been 6 days since I sent payment and I hadn't heard from him so I asked what the status was and he say he had shippped the stuff..I ended up getting it a couple hours later.
I can vouch that I did get everything, in exact condition described, relitively quickly. If you want a tracking number you should probably just mention that to him..
Old Dec 17, 2010 | 07:33 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
dateSun, Dec 12, 2010 at 10:09 AM
subjectRe: dash pad
mailed-bygmail.com
hide details Dec 12 (5 days ago)
Please let me know when it has shipped along with the tracking number. Thanks
Old Dec 19, 2010 | 01:50 PM
91camaro248's Avatar
Car: 91 Camaro RS
Engine: 350 +60 Air gap Custom 750 DP
Transmission: 700r4 Stage 2 2400 stahl
Axle/Gears: Aussie 9 3.27 Posi
still have the rear 1.5 lowering springs??? stock?? brand?? shipped to 48362 lake orion michigan? thank you
Old Jan 2, 2011 | 02:10 AM
*84TA's Avatar
Car: 84 Trans Am
Starter still for sale? If so PM or e-mail ms1095@gmail.com
Jeremys87
Jul 14, 2022 09:08 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
3rdgenparts
Aug 8, 2015 07:09 PM
