[MO] SDPC vortec TPI intake manifold @ stock tpi set up.
Old May 7, 2011 | 08:13 AM
jonnybcamaro's Avatar
Car: 02 T/A
Transmission: Built 4L60E
Axle/Gears: 3.42 Posi
It has been ported, has siamesed runners and port matched plenum, includes fuel rail. asking $350. *sold*
Stock 89 tpi intake includes TB, AFPR, injectors... $150
Attached Thumbnails SDPC vortec TPI intake manifold @ stock tpi set up.-wp_000026.jpg   SDPC vortec TPI intake manifold @ stock tpi set up.-wp_000029.jpg   SDPC vortec TPI intake manifold @ stock tpi set up.-wp_000031.jpg
Last edited by jonnybcamaro; Jun 15, 2011 at 07:21 AM. Reason: sold vortec intake.
Old May 10, 2011 | 10:43 AM
Car: 02 T/A
Re: SDPC vortec TPI intake manifold @ stock tpi set up.
bump
Old May 10, 2011 | 01:40 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
What brand are the runners?
Old May 10, 2011 | 02:51 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Axle/Gears: 12 bolt 3.73 Eaton posi
They look like stock runners that were cut open and had a plate welded to them so the two runners became one huge runner.
Old May 11, 2011 | 08:17 AM
Car: 02 T/A
that would be correct racing geek.
Old May 11, 2011 | 08:39 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The intake base is for Vortec heads? Not standard SBC1 heads?
Old May 11, 2011 | 11:44 AM
Car: 02 T/A
They bolt up to vortec heads, yes, not standard sbc heads.
Old May 11, 2011 | 02:33 PM
wesilva's Avatar
Transmission: 200R4
Did you run this combination? Was there any vacuum leaks? What gasket set did you use? What are the mounting tabs on the runners for? Interested but want more details.
Old May 11, 2011 | 05:16 PM
Car: 02 T/A
PMed
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
marcusaw
Aug 10, 2015 08:13 AM
