Small Cap Distributer and External Coil for TPI cars.
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Hello, I have a small cap distributer and a external coil for a tpi car for sale. Im asking $50 plus shipping. Thats less then what i payed for then and i havent even installed either one. So dont ask for it for less.
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: Small Cap Distributer and External Coil for TPI cars.
What brand is the distributor?
Both appear to be the factory parts or stock replacement parts. I haven't taken the cap off to see if it's got a different ign module in it however.
Bump
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
No, I bought the coil off of a guy here that was parting out a car. And bought the distributer off ebay. Both used. I never installed either of them onto my car because i switched to a tpi harness that was for a large cap distr.
The small caps were used after 86 in the cars with TBI or TPI. 92's either had TBI or TPI if i remember correctly so it will work with yours as long as you have that. If its a carbed car with vac adv. then it wont work. If you want it, its yours for $40 plus ship. Im taking a loss at that price.
Here are pictures.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
you should post a picture of the flange. there are a difference for the later tbi car's and trucks and will not work on a tpi. the coil bracket you have is tbi.
Here is a pic of the flanges. I was unaware of the differences so thanks for pointing that out. It looks like mine is the smaller flange. I also was sold the coil as a tpi coil, but if its for a tbi then im glad it was noticed now instead of after its sold. As i said i never installed these.
Engine: Lb9
Transmission: M20
coil will work on tpi and so will the dist. the coil bracket will only mount on tbi intake.
Cool thanks for clearing that up. Learn something new everyday.
Still have these. As shown in the pictures and confirmed by tunedperf. it works with any tpi car that has a small cap distr. and so will the coil, but the bracket for the coil is to mount to TBI.
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
