HELP with new H4 Headlights!
Old Jun 24, 2002 | 01:23 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
HELP with new H4 Headlights! PLZ!!!
Ok i just got my new diamond cut headlights wiht H4 bulbs, I installed them and turned them on to see how they look, and when i did, the high beams came on to. I flipped the turn signal thing to turn them off, but that just made them brighter, So when i turn on the low beams the high beams come on too?? Can anyone help me with this? Thanks Alot.
Old Jun 24, 2002 | 01:48 PM
Quick6's Avatar
This is what it looks like. Thanks for any help.
Old Jun 24, 2002 | 02:16 PM
Blackened's Avatar
That's because H4 bulbs were never designed to work with the harness in our cars. You need to so some cutting and rewiring. There's a tech article about this.
Old Jun 24, 2002 | 02:34 PM
Jza's Avatar
Jza
You don't need to cut anything, you can simply pull the pins out of the connector and insert them into the proper position.
But your problem is that H4s use the same connector, but the pins do different things.
Old Jun 24, 2002 | 02:40 PM
Blackened's Avatar
Pulling the pins out of the connectors is not a simple as you make it sound. I'd rather cut two wires and reconnect them with buttconnectors. Much easier....
Old Jun 24, 2002 | 03:01 PM
Quick6's Avatar
Ok I got it working and they look great. What Jza suggested worked great and was not to hard. Thanks for all your help.
Old Jun 24, 2002 | 04:30 PM
Jza's Avatar
Jza
Are you serious? I just inserted a paperclip into the release slot and pulled the wire out the back.
Old Jun 25, 2002 | 08:33 PM
Coop89RS's Avatar
What r these H4's? Are they brighter and where do you get them? Thanks.
Old Jun 25, 2002 | 10:51 PM
Jza's Avatar
Jza
H4's (and similar) are the little bulbs that plug into the plastic headlight housings in most newer vehicles (usually imports). "H4" is just the part number of the bulb, like "H4656" is the number for the bulb used in Camaros.
Old Jun 26, 2002 | 04:49 AM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
when I purchased mine they came with adapters!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
