Idk where to post this but what belt size do I need and how to route it if I delete ac and smog and do I need a different tensioner and don’t want to use the idler pulleys they make to replace them just want to get red of them completely trying to make more space for turbo
You will need to run the A/C delete pulley unless you want to go to a custom pulley set. Without the A/C idler pulley there would not be any way to tension the belt with the stock setup.
I wouldn't say it can't be done, but if you can build a turbo setup, you can probably figure out a way to mount the power steering and alternator without the factory serp brackets.
