Took lock off of my 91 RS how do i get it unlocked?
i took a screwdriver and busted the lock out and still can't get the door open. anyone ever done this and know how to unlock it from the outside?
Get a strong metal hanger, straiten up the part that the cloths hang on. Then use the "hook" and pt it between the window and rubber strip on the door. Feel (carefully) for the cable then move the hook from right to left (I think).
Hope it helps
Hope it helps
Kick in the window j/k. Hmm...the hanger method should work. These cars are wa to easy to break into. Also, out of curiosity, why'd you take the lock off??
Tim:rockon:
Tim:rockon:
What cable???? NO cable!!!! The car uses little rods to attach things.Feel (carefully) for the cable
First of all before I give a proper answer here...I want to know why you used a screw driver to pop the lock out? When you give me a honest answer to my question...I will give you one for your question.
Sorry I foregot about that...but shouldn't that method still work though?Originally posted by Cruzin Kaz
I'm not sure but I don't think so. I really shouldn't post this here anyway, but use a flat piece of metal and push down above the lock mechanism. I am not going to say it anymore detailed cause these car are easy enough to steal as it is...I am not going to contribute to the training of theives. Plus..91RSGYEA has still not told us WHY he took a screwdriver to the lock to begin with.
