Firebird Taillight Centerpiece mod and instructions...(getting the bird to glow)
Old Mar 30, 2011 | 09:51 PM
  #51
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Firebird Taillight Centerpiece mod and instructions...(getting the bird to glow)
pic 1 and 2 i used HVAC aluminized tape on the body and the back of the center to reflect as most light as possible. other wise the light from the bulb was to focused. I used a rubber grommet around the lock to keep water out and light in.
Attached Thumbnails Firebird Taillight Centerpiece mod and instructions...(getting the bird to glow)-dsc02109.jpg   Firebird Taillight Centerpiece mod and instructions...(getting the bird to glow)-dsc02118.jpg
Old Mar 30, 2011 | 10:01 PM
  #52
91banditt2's Avatar
Engine: 5.7 HSR
I used a 3157 bulb which is a duel filiment bulb. I used this because i wanted to make sure that this wasn't brighter than the other bulbs that i was going to be using with my Sequential turn signals. I don't remimber the part number for the 3157 socket. I tapped into the wires for the license plate light.
Attached Thumbnails Firebird Taillight Centerpiece mod and instructions...(getting the bird to glow)-dsc02110.jpg
Old Mar 30, 2011 | 10:02 PM
  #53
91banditt2's Avatar
Engine: 5.7 HSR
Attached Thumbnails Firebird Taillight Centerpiece mod and instructions...(getting the bird to glow)-dsc02117.jpg   Firebird Taillight Centerpiece mod and instructions...(getting the bird to glow)-dsc01402.jpg
Old Apr 4, 2011 | 03:16 PM
  #54
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I am working on a set of 84 T/A Tails and will be making the center light up. It is however much much harder as I want the design on the inside so I had to separate the front from the back and lighting is now harder. Plus the 5/8 inch wide grooves. The decals will be made in reverse to go on the inside. I got the idea from a thread about it on a 4th gen. Seems that the 4th gen people aren't going to have a monoply on this are they? I expect to have the only set of 84 Tails done similar to this.
Old Apr 8, 2011 | 05:35 AM
  #55
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Originally Posted by HCR13
The only exception is that when I printed the "Trans Am/Firebird" stencils, I went into Windows Paint and mirroed/reversed the image so it printed it backwards, ...
Where did you get the "Trans Am" lettering for the stencil? I would like to do this but with a different picture on the bottom. Thanks.
Old Apr 30, 2011 | 02:00 AM
  #56
SpeedDemon91's Avatar
Car: '18 Jeep Wrangler, '19 Honda Accord
Engine: 2.0T in both
Transmission: 8 speed auto, 10 speed auto.
Crap!! ya can't do this to a '82??
Old May 2, 2011 | 06:10 PM
  #57
91phoenix's Avatar
I will not say you can or can't but it is much harder if possible. The bird emblem in the center is removable and replacable so it might be possible. But the center is both a front piece and a back panel so lighting becomes a lot harder to do. I have one center separated and a spare and am getting another to play with so I can see what can be done. Will not be anything quick to accomplish though.
Old May 6, 2011 | 12:09 AM
  #58
hornick's Avatar
Car: 1986 Trans Am WS6
Engine: 305TPI
Axle/Gears: 3.42 (I Think)
I too am considering the possibilities to making a TA center section light up... anyone know a way to transplant the reflective strip to a firebird center section? Is it even possible? I think that if u were to scan the emblem reverse mirror the image and take ur time cutting it out and painting you could do this. I am considering painting the entire emblem recess red on the inside and making the bird emblem red on the back where it is now gold. I will then use a brighter a LED bulb... since its gotta shine thru 2 layers... any other ideas out there?
Old Feb 26, 2012 | 06:55 AM
  #59
Car: 1988 GTA
Engine: 400 CI
Practice one from the junkyard.
Attached Thumbnails Firebird Taillight Centerpiece mod and instructions...(getting the bird to glow)-taillight-006-small-.jpg
Old Mar 25, 2025 | 04:10 PM
  #60
firebird5.0's Avatar
What grid of sand paper do you start out with. to mod the center tail light to light up on Firebird Formula 89.
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
Catcher55
Aug 15, 2015 07:08 PM
