Feb 29, 2004 | 05:44 PM
Not sure if this is the right place for this or not. But ok the seal on my driverside t-top leaks water when it rains and when i wash my car. Any1 have any ideas on what i could do to stop the leak?
Reply 0
Mar 1, 2004 | 03:51 PM
the only way to stop the leaks for good is to replace the weatherstripping on the car, but then agian sometimes it still leaks, it might be an alignment issue as well, or you could always find out exactly where it is leaking, and put some caulk under the weatherstrip to raise it up and seal it
Reply 0
Mar 1, 2004 | 10:08 PM
Re: T-Tops
Quote:
What part of the seal does it leak from.Maybe you just need to adjust your window
Reply 0
Mar 3, 2004 | 01:05 PM
My 3rd gen doesn't leak, however, my 93 did. Yesterday I took both door panels off and made adjustments to the window regulators and stops. I sprayed it with direct pressure from the hose and not a drop now. I might still replace the weather stripping, but the car stays dry in the rain now.
Reply 0
Subscribe
