its the hydraulics lever thing from under the hood.. wats it called?
mines f****d i think thats why my hood was cracked underneath, it wasnt bending properly, but i got a new ss hood
so i better change that piece before it break this too.thx
Hood struts... You can generally replace both for 50.00 or less through classic industries or any other online store. I believe even cheaper through Autozone or something...
Dirtbik3r
close
- Join DateOct 2003
- LocationLaGrange (10min from Poughkeepsie), NY
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1992 Camaro RS - not real slow anymore...
- EngineSPDC 360 MAF EFI /w a Holley Stealth Ram
- TransmissionT5 untill it blows up from to much torque
- Axle/GearsFord 9" /w auburn pro & 3.89's
- Liked:0 Times in 0 Posts
do they sell hood struts for fiberglass hoods?
Quote:
Yes Originally posted by Dirtbik3r
. Just get the hood struts designed for the stock 82-83 fiberglass hoods. Im pretty sure the part # has been posted before, just do a search.TGO Supporter
If you go to www.autozone.com , locate your region of living, search for hood or hatch struts, select your year, make, model, etc. of car, it will give you the p/n and the price to take to AZ (for your region). Assumption here - the MightyLift p/n should be good at any local chain store so you don't have to go to AZ specifically.
MightyLift pretty much makes the hood struts for all year, make & models of Firebird & Camaros. They also make the hatch struts for all years, makes, models as well. Price shouldn't be a concern if you want them to last. Most MightyLift struts also come with a lifetime warrenty.
Otherwise.. go pull some turds off a used car in the junkyard and then, revert to the top of this statement (unless, by fate, you somehow find some good one in the junkyard).
