87, 88, 89 Ten-Bolt Owners, Come In
Old Nov 3, 2010 | 06:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you have OE rear disc brakes in the above years, please post the year and model of your car. Many thanks.
JamesC
Old Nov 15, 2010 | 08:35 PM
JamesC's Avatar
Re: 87, 88, 89 Ten-Bolt Owners, Come In
TT.
JamesC
Old Feb 16, 2011 | 11:31 AM
scooted45's Avatar
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
1989 iroc, t5, 5.0 tpi. Has a 7.5" I think. Anyone know if these rotors brackets can be swapped to a drum axle? Trying to change my ratio from 2.73 wout tossing the discs.
Old Feb 16, 2011 | 11:37 AM
JamesC's Avatar
An 89 (7.6) with discs should be a 9-bolt with PBR's. Check the following link toward the end for more info on the swap:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 16, 2011 | 01:10 PM
scooted45's Avatar
No, sorry to hijack the thread, Ive got the delco moraine style ambidextrous iron calipers. I bought a rebuild kit once and found that my car was supposed to have pbrs. Ive already read the link you cited and found a drum flange needs to be swapped with a disc flange. Is that correct?
Old Feb 16, 2011 | 01:13 PM
scooted45's Avatar
Maybe it is a 9 bolt. it has a filler cap on the diff. Sorry, thought it was a 10 bolt.
Lbibb
May 5, 2016 12:00 AM
Briandrex
Oct 5, 2015 06:20 AM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
