I bought a Strange 12 bolt rear for my iroc. I could not use my original drums anymore so i had them put on the brackets to accept the 93-97 camaro disks. I have them installed and they fit great. Only thing i dont have is the brake lines hooked up, i bought remanufactured Z28 brakes which didn't come with the hardware. Whats the best idea to hook up the brake lines. I was thinking a 10mm pipe to 3-AN fitting form Aeroquip or some other manufacturer, and then running a small braided line from the cliper to the original distribution block (hard line from the front of the car) Anybody do this or any any other suggestions??
Stock from disk..
Stock from disk..
Ok well no reply's.. But i found an answer which worked awesome, i looked up brake accessories from Earl's. Perfect! I ended up buying 2 10mm banjo bolts and a 10mm banjo fitting to -3an, then a couple -3an braided brake lines. Fit perfect and looks sweet too
