Another factory caliper swap idea to consider
Subscribe
Oct 14, 2007 | 11:26 PM
  #201
Re: Another factory caliper swap idea to consider
Ed,
Did you get something with the 13.5" done too?
I am looking at being right at 7.5" from center of spindle for clearance. I am probably going to have to get a more accurate measurement, and probably have you get a more accurate measurement to see if it will work. Or see if you can borrow a C5 front wagon-wheel for fitment.
--John
Reply 0
Oct 15, 2007 | 03:26 AM
  #202
The 14" was an easier go of it, the 13.4" will be the same but let me get this one set up and finalized first. In theory, all I'll have to do is move the holes inward .300" which is no biggie but it'll put those big *** caliper lugs closer to the bracket. I may be able to bum a wagon wheel from one of my local guys, and he has spacers to boot. I'll keep you posted.
Ed
Reply 0
Oct 15, 2007 | 02:43 PM
  #203
Thanks Ed, let me know what happens!
Reply 0
Oct 19, 2007 | 10:58 PM
  #204
As far as the subu and mits brembos go have you guys seen this, would this be work for mounting for us? It would be great if it did as those little kids that get those cars are always crashing them so its not hard to score a nice set of brakes cheap
http://www.camarotech.com/brakes-Brembo.html
Reply 0
Oct 20, 2007 | 01:39 AM
  #205
tt
Reply 0
Oct 20, 2007 | 05:02 AM
  #206
Price that Firehawk bell and rotor and get back to me, please. I doubt that's anything close to a budget setup, no offense.
I have a set of Brembo Evo calipers in the shop and will work more with them as time allows but first things first. Pics of the full finished setup coming over the weekend.
Ed
Reply 0
Oct 23, 2007 | 10:54 PM
  #207
As promised here's the pics:
7.5" from center to outside of caliper, 2" from hub face to outside face of caliper. The best part is that I didn't have to touch the caliper, my bracket clears it just fine.
Enjoy!
Ed
Reply 0
Oct 24, 2007 | 10:17 AM
  #208
that looks damn nice,ed have you set a price yet?
Reply 0
Oct 24, 2007 | 11:10 AM
  #209
I'll have to verify the price of the loaded calipers again but it's looking right at $1000 or so off the top of my head..this includes everything you see and braided lines too. Give me a day or so to get the numbers correct. I'm also thinking these will fit a 17" wheel.
Ed
Reply 0
Oct 24, 2007 | 11:24 AM
  #210
Ed,
THANKS. Those look great. If you could test fit a 17" wagon wheel, that would be huge for me, I think we are going to be right there, give or take 1/4" But I am a little scared to try it without really good measurements.
I'll e-mail you about some things, I obviously don't need everything there, I will need to work with you on what peices I need.
BTW, That does use standard hubs, not 1LE, correct?
--John
Reply 0
Oct 24, 2007 | 01:21 PM
  #211
Ed, one other thing, looking at it, is that 7.5" the furthest point? It looks like the ends of the caliper are thicker than than the center, what is the measurement at that point?
Reply 0
Oct 25, 2007 | 06:55 AM
  #212
--John
Yes, standard hub. I think I can contact a local guy this week to test it out. I'll get back to your message later today.
Quote: Ed, one other thing, looking at it, is that 7.5" the furthest point? It looks like the ends of the caliper are thicker than than the center, what is the measurement at that point?
I understand..I'll check that for you as well.
Ed
Reply 0
Oct 25, 2007 | 12:45 PM
  #213
Cool, thanks Ed. I won't clog up the thread anymore, you have my e-mail.
--John
Reply 0
Nov 8, 2007 | 08:35 PM
  #214
John, as you suspected the caliper is a bit thicker in that area and the distance to that area is just a hair under 8".
For all others, this new big brake setup fits into a 17" wheel so we have yet another option out there. I'll post up pics when I can get to it.
Ed
Reply 0
Nov 9, 2007 | 10:56 AM
  #215
Ed, which 17" wheels did you test it with, the C5's like I have?
Reply 0
Nov 9, 2007 | 06:30 PM
  #216
hay i got 17 inch snypers on my iroc, this setup should work....whats included in it, rotor(what kind c5 ???) caliper, cusotm caliper braket and what else ...what gotta be done to the stock spinle to ...anything...?
Reply 0
Nov 10, 2007 | 10:44 AM
  #217
Quote: hay i got 17 inch snypers on my iroc, this setup should work....whats included in it, rotor(what kind c5 ???) caliper, cusotm caliper braket and what else ...what gotta be done to the stock spindle to ...anything...?
Take a closer look at the thread please. You'll need modified spindles, hubs, and brackets to install the calipers on your car...brake lines as well. 14" C6 rotor, STS-V caliper/pads, my bracket. Ideally this will run with a 1.75" spacer and 4th gen or C5 offset wheels.
PM me or e-mail for more info..thanks!
Ed
Reply 0
Nov 13, 2007 | 05:36 PM
  #218
Have you gotten pics yet Ed?
Also, I e-mailed you again.
Reply 0
Nov 13, 2007 | 05:42 PM
  #219
well i pmed you ed a while back about a set of z06 fronts for my iroc you never got back to me...months ago...anyway so how much and what will it take to get these on my car...you should write like a guide for all your sets that you make...make your life a lot easier...let me kno.
Reply 0
Nov 13, 2007 | 09:03 PM
  #220
My apologies as I haven't replied to many yet. I'll PM you.
Ed
Reply 0
Dec 2, 2007 | 10:20 PM
  #221
Ed,
Did you ever get pictures of these behind wheels?
Reply 0
Dec 2, 2007 | 11:07 PM
  #222
Just a guess that this is one more cool brake setup I can't fit behind R15s..
Reply 0
Dec 3, 2007 | 06:51 PM
  #223
Quote: Just a guess that this is one more cool brake setup I can't fit behind R15s..
Yep...I've only worked this with the 14" rotor and the 13.5" Z51 rotor won't be that much smaller. I still need to get pics done but I'm busy with other stuff and my test rotor is not on hand right now.
Ed
Reply 0
Dec 3, 2007 | 07:35 PM
  #224
If Ed wants me to test one out for him I can.......
Reply 0
Dec 3, 2007 | 09:47 PM
  #225
Thanks for the offer..where are you again?
Ed
Reply 0
Dec 3, 2007 | 10:02 PM
  #226
Quote: Thanks for the offer..where are you again?
Ed
I am in NJ, Trenton area
Reply 0
Dec 4, 2007 | 12:33 AM
  #227
would be nice to know exactly what fits.. I am too far away in Idaho.
Reply 0
Dec 4, 2007 | 09:33 AM
  #228
Hmm....so if I read through all 5 pages correctly...
Since I already have LS1 brakes, 1.7" spacers, and 17" WS6 4th gen wheels... I can buy the bracket from you Ed, get the calipers and lines and rotors, and then bolt them to my spindles that are already modified for LS1 brakes? Or are these spindles modifed differently still...???
Maybe I didnt read good enough!
J.
Reply 0
Dec 4, 2007 | 10:26 AM
  #229
Most, if not all kits, use the factory dust sheild holes that have been drilled and tapped for larger bolt holes. This one should be no exception, so you should be able to buy this and just bolt it on without any more modifications to your spindles.
Reply 0
Dec 4, 2007 | 11:32 AM
  #230
Sweet.... C6 rotors, CTV-S calipers, Eds bracket, and some lines... Now...the hard part. Deciding if I want to do this to replace my LS1 brakes...haha.
J.
Reply 0
Dec 5, 2007 | 09:05 PM
  #231
absolutly excellent.
Reply 0
Dec 11, 2007 | 11:29 AM
  #232
Hey Ed. I just got my Tax Kicker back..... any news on this, the money is burning a hole in my pocket!
--John
Reply 0
Dec 11, 2007 | 02:23 PM
  #233
Ditto...ive been trying to get a hold of you ed check your PMs!
-Steve
Reply 0
Dec 12, 2007 | 01:47 AM
  #234
Talked to Steve today, I'll get to it as soon as I can John. I know you need them in a hurry.
Ed
Reply 0
Dec 12, 2007 | 12:37 PM
  #235
Thanks Ed. Just e-mail me. At this point, I couldn't install them until after the holidays anyway, but I would like to get everything ready to roll, and also be able to machine the hubs for the diffrent rotors. Just let me know the price breakdown on the parts from GM, I think your guy was a little cheaper than my guy, but depending on timing, I may just need to go buy a set of rotors, so I can do the machine work on the hubs. I want to make sure before I spend to money on this stuff vs. wilwoods, that it will for sure clear my wheels.
--John
Reply 0
Dec 31, 2007 | 07:45 AM
  #236
Ed,
Can you please e-mail me. I need to do something in the next week or two...
--John
Reply 0
Jan 2, 2008 | 01:43 PM
  #237
--John
Ho ho ho..Hi John, I"ll send you one out momentarily. I am making the brackets this week so I figure a week to get them back from plating unless you want them bare. Check your mail.
I ended up having to clock the caliper lower than pictured above to clear the casting and you'll likely have to clearance the bracket a bit but they'll fit. I'm also making a setup for Stevo and I'll make 5 pair of brackets for the 13.4" Z51 rotors, leaving 3 sets open for other members. Thanks fellas, Happy New Year!
Ed
Reply 0
Jan 2, 2008 | 04:34 PM
  #238
Thanks Ed-clause!
I e-mailed you back, asking about a few diffrent things. I am ready to roll, if you e-mail me back so we can get cruising on this.
Reply 0
Jan 16, 2008 | 10:01 PM
  #239
John, I'll get with you tomorrow. First off, this setup is tight on the lower part of the spindle. Also, you must use the lower spindle bolt I provide with the bracket and it's a metric thread you'll need to tap for the lower spindle hole and trim the bolt to fit. The bolt has a very thin head which is necessary to fit between the caliper casting and bracket. Additionally, you'll have to clearance the caliper a bit in the area under the bolt head...it's that tight in there. Big caliper, not a lot of room. In order to fit the caliper is clocked very low on the rotor and I don't see any contact issues but you may if you turn the wheels to lock consistently. You will also need to run a brake line with a 90* lower fitting on the banjo bolt fitting. Other than that, the 13.4" Z51 rotors are a go as well for the CTS caliper. I tested this setup using a 17" x 9" wheel with a 4th gen/Corvette offset and a 1.75" total thickness spacer, obviously a 2" will give you more clearance. The caliper has less than 1/4" clearance to the wheel rim when fully seated..again, it's tight!
Pic of the type of bolt needed to be used and the spacer used on the caliper lugs between the bracket:
90* brake line fitting:
You'll need additional clearance here, even with the thin bolt head:
Clearance to wheel. I put tape on the caliper to protect it just in case it hit:
Ed
Reply 0
Jan 26, 2008 | 04:30 PM
  #240
so is this now a complete kit your going to be selling?
Reply 0
Jan 27, 2008 | 10:50 PM
  #241
Yes, currently I can do the 13.4" Z51 and 14" ZO6 C6 rotor sizes.
Ed
Reply 0
Jan 29, 2008 | 02:49 PM
  #242
Ed, did you ever get my e-mail?
Reply 0
Mar 15, 2008 | 04:33 AM
  #243
Ed, bringing this back up. I know you had some family stuff to deal with. Did you ever get my e-mail? I am still in need of brakes. Which model wheel was it that you did the test fit with?
Reply 0
Mar 15, 2008 | 01:11 PM
  #244
Whoops...sorry John. I'll check and resend you mail.
Ed
Reply 0
Mar 16, 2008 | 09:40 PM
  #245
So the 14" rotor is for 18" wheels only, and the 13.4 c6 z51 rotor is for 17" wheels?
Or did you manage to get the 14" rotor to work on 17" wheels?
sorry, I am a bit confused after reading this thread. I only remember you saying that the 14" rotor worked, not what wheel size it would have to be used on
Also, I take it the 14" rotor you used was a c6 z06? would the stock cts-v 14" rotor work the same?
thanks!
Reply 0
Mar 17, 2008 | 04:35 AM
  #246
Member Stevo just installed the 13.4" setup, here's the link. Check his post for specifics:
https://www.thirdgen.org/forums/cama...ght=cts+brakes
I can't guarantee that NO 17" wheels will hold the 14" setup but I can't tell you that. Should you know the wheels you'd like to use I'll look into them for you, but I do recommend 18"s for the 14" rotor setup. The CTS-V wheels are 18" x 8.5" 42mm offset, Bolt Pattern: 6 x 115.
These rotors are C6 ZO6 and Z51 factory rotors. The CTS rotors won't work since they're 6 lug.
Ed
Reply 0
Mar 18, 2008 | 06:58 AM
  #247
I KNEW that the cts-v rotors were 6 lug, too!
can you pm me with a price on the caliper brackets or post it on here? I want to run the 13.4" z51 rotors as I have 17" c6 Z06 wheels and I don't want to chance the 14" rotor rubbing.
If you have the ability to test fit that rim and see if the 14" rotor works I'd really appreciate it, but I understand if you don't have access to that wheel.
Am I correct in saying that I wouldn't need to machine down my NON 1LE hubs if I was using the c6 z06 rotor, and if I run the c6 z51 rotor I have to machine it? Or am I backwards?
Thanks!
Reply 0
Mar 21, 2008 | 10:16 AM
  #248
The thing is that the ZO6 rotors have a radius on the inside that the hubs have to account for. It will all depend on what the OD of your hubs are as to whether you can use them as they are. I preradius all my ZO6 rotor spec hubs to they can be used on all C5 and C6 setups for this reason. Most of my kit brackets run $75-85/pr and are zinc coated as well.
I will go ahead and state that the 14" rotor will not clear a 17" wheel with that caliper, it's just that big. CTS-V wheels are 18" x 8.5".
Reply 0
Mar 25, 2008 | 08:35 AM
  #249
Hi Ed, just another quick question before I get started on this project.
I currently run 2.25" spacers on the front of my car to make my 17x9.5 56mm offset rims fit.
Once I install the c6 z51 rotor , do you know how much farther out the brakes will move the wheel compared to the stock brakes?
I'd like to know at least roughly to see how much I'm gonna have to turn down these spacers.
thanks for all your help!
Reply 0
Mar 25, 2008 | 09:26 PM
  #250
I just installed the 13.4" C6 Z51 rotors with CTSV 4 piston brembos and they clear C5 z06 wheels with a 2 1/4" spacer as well as they will clear 17x9" ROH Snypers(no spacers) so this setup should be clear other 17" ROH Wheels. I can post pics if anyone would like. This is pretty much the max size rotor, 14" will not fit.
Just some insight for those who were wondering.
Reply 0
