Suspension or Brakes
Subscribe
Jan 10, 2009 | 08:07 AM
Had this problem for a while and parked the Camaro while I could work on it, but to no avail... The car pulls hard right when I brake.
92 Camaro Z28
Replaced all rubber brake lines
New master cylander
New brake calipers
New pads
New cylinders in the rear drums
Flushed old brake fluid
I have checked all the suspension components up front and it all appears nice and tight.
Could it be a bad ball joint?
Oh, shocks and struts are about 3 years old, KYB GR-2. Replaced all bushings at same time with Poly stuff. Had this issue prior to all this work.
Any thoughts??
Reply 0
Jan 13, 2009 | 10:51 AM
Re: Suspension or Brakes
are your right pads more worn than your left pads?
sounds like brakes to me
Reply 0
Jan 13, 2009 | 03:37 PM
If the car pulls right, something is wrong with your brakes on the left side. The left side of your car continues on, while the right side slows down, causing you to pull right. Since most of the braking is done up front, I'd check the left caliper. Maybe you got a defective caliper? If the car pulls HARD right, the left side isn't working too much, if at all. I wouldn't think its a suspension problem, but I could be wrong.
Reply 0
Subscribe
