ok 4th gen brakes I know there used but....
Subscribe
Jul 13, 2011 | 11:51 PM
If I had the entire spindle, rotors, caliper, etc. could I use the entire setup or do I have to be stuck modifying my spindles.
Reply 0
Jul 14, 2011 | 06:40 AM
Re: ok 4th gen brakes I know there used but....
[QUOTE=sk8r fer life;4978304...or do I have to be stuck modifying my spindles?[/QUOTE]
Yes.
JamesC
Reply 0
Jul 14, 2011 | 10:10 AM
4th gen spindles are not even close to working on 3rd gen cars.
Here's modded 3rd gen LS spindles (powdercoated)
Here's stock 4th gen LS spindles and hubs
Reply 0
Jul 14, 2011 | 12:43 PM
I see, ya I was told the spindles would work but I didn't think they would from looking at the to lt1 fbodys in my driveway but I wanted to double check Ill just modify mine.
Thanks Tim
Reply 0
Jul 14, 2011 | 04:21 PM
rob you didn't cut off the lower portion of the spindles, so I'm guessing you're running both bolts through the front then? I ran mine opposite of each other, top bolt is from the front and bottom bolt is from the rear, that way the caliper won't have contact issues was my thinking.
Reply 0
Aug 10, 2011 | 09:01 AM
Quote: rob you didn't cut off the lower portion of the spindles, so I'm guessing you're running both bolts through the front then? I ran mine opposite of each other, top bolt is from the front and bottom bolt is from the rear, that way the caliper won't have contact issues was my thinking.
just noticed that myself, but I thought that had to go for clearance of the caliper itself? I couldn't get mine to fit without that tab being gone, but I haven't looked at the setup in a bit for reference.
Reply 0
Subscribe
