Hey, I have found these subs for $55 a piece plus shipping and handling. They seem pretty good and look good too. Tell me what you think and if any one has them, tell me how you like them. Also, what would be a good amp to power 2 of them? Thanx!
Pioneer COMP DVC 12":
12" Foamed IMPP (Injection Molded Polypropylene) Rigilite Composite Cone Woofer
Dual-Layer Urethane Surround
Direct Bobbin Mounted VCCS (Voice Coil Cooling System)
Conex Damper with Damper Ring
Lead Wires Integrated into Damper for High Reliability and Improved Power Transfer
Projected Pole Yoke with Vented Pole
High-Energy Ferrite Magnet with Bumped Back Plate
Low-Q Design for use in Small Sealed Box (1.2 cubic foot recommended)
Dual Voice Coil (2x4ohm) Design for Increased System Flexibility
600 Watts Max Music Power
300 Watts Nominal Power Handling
Frequency Response: 18-2,000Hz
Sensitivity (Efficiency): 89dB (1W/1m)
2ohm or 8ohm Rated
2ohm or 8ohm Rated
I agree. For $55 a pop they're a good deal. As long as they're set up properly and you don't push them beyond their limits, tehy will give satisfying bass. It won't be the loudest, and it won't eb the absolute cleanest, but you will enjoy them.
