Jun 26, 2003 | 11:34 PM
is there anyway to make a box to fit three 12's in the back of the car (in the hole)?
Reply 0
Jun 26, 2003 | 11:43 PM
In the hole, no. in the hole and over the gas tank some, yes.
Brian
Reply 0
Jun 26, 2003 | 11:48 PM
pictures?
Reply 0
Jun 27, 2003 | 11:33 AM
anyone have any pictures of custom boxes that holds three 12" subs?
Reply 0
Jun 27, 2003 | 11:36 AM
Quote:
Brian
I disagree with that statement, you can fit three 12's in there easily with the right kind of box.
Reply 0
Jun 27, 2003 | 11:43 AM
you can fit 3 but you really only have airspace for 2.
Reply 0
Jun 27, 2003 | 02:15 PM
Quote:
I hope that you are right, but in just the hole I dont see it happening. I think you are going to have to use up some of the part above the gas tank. I will have to check it out later to see. Just like the old saying goes, "whats better than two 12s, three 12s "
Brian
Reply 0
Jun 27, 2003 | 02:37 PM
that is an old saying? there ARE subs out there that dont take 1.4+ cu. ft a piece, in cases like the third gen, i would think that people would look into them.
adam
Reply 0
Jun 27, 2003 | 03:05 PM
i'm getting a hell of a dell on three subs, that's why i need to know if all three will be able to fit in the hole , and a picture of the box so i know what i'll have to build .
Reply 0
Jun 28, 2003 | 09:47 AM
Brian
I disagree here as well...you have enough airspace and room to fit 4 12" Type R subs in the rear well. You would have to mount 2 of them in the center facing up and 2 on the outside at an incline facing up and in.
Reply 0
Jun 28, 2003 | 03:22 PM
yes you can do 3 in the hole. you can find a pic of the box with a search im sure. i could probably build you one if you told the specs of the speakers. let me know.
Reply 0
Jun 28, 2003 | 04:31 PM
they are audiobahn alum 12" subs. if you could just draw a picture to give me an idea that will work. thanks.
Reply 0
Jun 28, 2003 | 05:19 PM
what is the mounting depth? they will be a factor in the design of the top piece.
Reply 0
Jun 28, 2003 | 06:06 PM
i found the specs and the mounting depth should be enough for a normal design. i attached a file of what the top piece would look like with 3 12s. as far as the design, i wont go into that. if you want to build it yourself, you can probably find the plans somewhere on the net.
Reply 0
Jun 29, 2003 | 11:38 AM
Brian
i have a box that will fix 3 memphis 12's HP's in the hole in the back. i lost the pic of my box but i will go tot he shop where my box it and take some more pics. now if you wants 3 12's PORTED then no you can do 3 10's ported in the hole
Reply 0
Jun 29, 2003 | 12:04 PM
Quote:
Interesting how everyone is so quick to say no and yet nobody has a pic. If you read what kristopheer asked, "in the hole" you will realize that there is no room for three 12s "in the hole" I am attatching a pic of pat12spe box. It is "in the hole" Are you guys trying to say that in the space where the hatch attatches to the car(where there is only 11.5") you are going to fit two pieces of 3/4" MDF and a 12" woofer??? I dont think you can do that. Maybe it was all that crazy learning I did in school, but 3/4+3/4+12=13.5 Does 13.5=11.5....UM......NOOOOO!
Now if you were to make the box come out of the hole(which I already said in a previous post, that I guess nobody wanted to read) you should have no problem fitting three 12s, as long as you have the air space.
Now lets recap.
Three 12s in hole, no
Three 12s in hole and out of hole, yes
Brian
Reply 0
Jun 29, 2003 | 12:09 PM
pic
Reply 0
Jun 29, 2003 | 12:11 PM
i'm on ym way to the shop to take some pics. :-D i will post the pics in about an hour.
Reply 0
Jun 30, 2003 | 09:29 PM
i cant wait to see those pics...
Reply 0
Jun 30, 2003 | 09:40 PM
Either can I. This is the longest hour of my life
Brian
Reply 0
Jun 30, 2003 | 09:57 PM
yea yea talk all your chit your just going to have to wait till i have time to scan them. and yes i did use a ruler to prove they are 12's and not 10's so talk all your chit all you can but your goign to shut up when you see the pics
Reply 0
Jun 30, 2003 | 10:29 PM
When I see the pics I will shut up. But I need to see how that sucker is in there. Just straight over from the gas tank is only 11.5" on my GTA. Is it different on yours? On anyones??
Brian
Reply 0
Jun 30, 2003 | 10:50 PM
I designed, but never built a box as I described above...I may have to build it now...just to prove a point! However, fitting 4 12" subs requires cutting out part of the rear plastic that is in the rear hatch area. If you are talking about doing it without modification, than I believe that 3 will still fit...you would have to make the top plate angled towards the front of the car which would give you more mounting area. I will have to measure to make sure...if correct, I will post the actual dimensions and some measurements.
Reply 0
Jun 30, 2003 | 10:56 PM
Quote:
Gotta love spite!
That is what I have been saying, you will have to make some of the box out of the well to get three to fit. I really want to see pics, I would love to have three 12s in the well. I dont want to build a box that will go out of the well. I have done a decent amount of research on this, but if someone can prove me wrong, PLEASE DO.
Brian
Reply 0
Jun 30, 2003 | 11:07 PM
I have a box built for 3 12"s it has between .75-1.0 cubic feet per sub, I am trying to sell it, and if you guys want a picture here it is
Reply 0
Jun 30, 2003 | 11:29 PM
That fits flush in the well? Even with the gas tank?
I took a couple of pics. The first is my hatch pull down, if a 3rdgen doesnt have the auto pull down, is it smaller?
Heres the pic
Brian
Reply 0
Jun 30, 2003 | 11:31 PM
Here is the pic of the distance between the edge of the hatch pull down and the edge of the well. There is only 12" if you were to stretch it a tad.
Brian
Reply 0
Jul 1, 2003 | 07:05 AM
its all in the air space specs of the subs. the memphis HP's can halnd the air space of the box :-D
Reply 0
Jul 1, 2003 | 07:06 AM
caleb why a stereo box and not mono?
Reply 0
Jul 1, 2003 | 11:03 PM
With this type of design 3 is easy to fit.
Reply 0
Jul 1, 2003 | 11:58 PM
that box I bought off another member that was closing his shop (username mathew 3:16 or somthing) anyway, it fit in my 85 Iroc that didnt have the hatch pulldown, and it barely fit when the hatch was closed, high excursion subs wouldnt work in it. I tried it when I got my 89 Iroc, that has the hatch pull down, and It wouldnt slide all the way into the well. I think its because the back is a tad wider for the hatch pulldown, but I may be wrong. I am selling it because as you can see in my sig I am going with fiberglass to save weight and because I am only going to be running one sub.
Reply 0
Jul 3, 2003 | 10:56 PM
www.ryjocustoms.com
Reply 0
Jul 4, 2003 | 02:28 AM
that fits three but not flush with the gas tank hump.
Reply 0
Subscribe
