Need antenna HELP! asap plz?
Subscribe
Sep 7, 2009 | 02:24 PM
Ok i have 86 TA the antenna is a motorized one which i knew would go bad well it got stuck up which is good but i cant get it to stop trying to pull it down wat color wire is for the antenna before i cut the wrong one
Help fast i need my car tomorrow for school and rlly would liek not to have to disconnect the battery everytime
Reply 0
Sep 7, 2009 | 02:32 PM
Re: Need antenna HELP! asap plz?
honestly man I would just unplug the motor at the back of the car underneath the antena that way your not cuttin wires if not required that would be the easiest way I think
Reply 0
Sep 7, 2009 | 03:19 PM
thanks dude but mine is in the front infront of the passenger door so i jsut opened this little plastic air intake thing infront of the door and just cut the two going directly to the motor so yeah xP
So nvm no help needed then im changing it to a non motor one =P
Reply 0
Sep 7, 2009 | 03:23 PM
ok sorry I was thinkin of my brother in laws car his mitshubishi did that and it was in the the trunk but hope it help either way...
Reply 0
Sep 7, 2009 | 06:52 PM
It's the pink wire behind the radio if you have a aftermarket radio its usually hooked up to a blue wire from the radio but the car wire should be pink.
Reply 0
Sep 8, 2009 | 12:44 AM
Quote: Ok i have 86 TA the antenna is a motorized one which i knew would go bad well it got stuck up which is good but i cant get it to stop trying to pull it down wat color wire is for the antenna before i cut the wrong one
If you take off the two parts of the kickpanel on your passenger side, inside the car, there should be a black 3-wire plug that you can disconnect that turns the power off to the antenna motor. That's what I had to do on mine to get the motor to stop running when my mast stopped going up and down but the motor kept spinning.
Reply 0
Subscribe
