electric fuel pump install
Subscribe
Oct 27, 2004 | 11:44 PM
Well im preping my car for nitrous, and im in the process of installing a electric holley red fuel pump, and wanted to see where and how you tapped into your fuel lines and where you mounted your pump.
Reply 0
Oct 28, 2004 | 11:59 AM
Back by the tank. On the flat surface in front of it.
Reply 0
Oct 29, 2004 | 11:41 AM
probably nowhere near what you wanna do, but pump location can be used.
electric fuel pump install-bird-pre-track-debut
Reply 0
Oct 31, 2004 | 12:35 PM
any closeups IHI??
Reply 0
Oct 31, 2004 | 01:01 PM
That's as close as I ever got, sorry on a sad note, I have to replace the A2000 pump. Went for a cruise the other day, 2hrs into it the pump died, looked under the car and both + and - had all the insulation melted off from the connection to the relay into the actual electric motor housing. Going to look into the Aeromotive S/S pump and that should be plenty for this motor, the A2000 was big time overkill
Reply 0
Subscribe
