Blow thru carb.?
Subscribe
Nov 14, 2005 | 04:15 PM
I am building a twin turbo 355 and I am going to run a carb and I need to know how to convert one to a blow thru. Or, of one from holley or demon that is already blow thru. Thanks
Reply 0
Nov 15, 2005 | 10:50 AM
This is what I'm going to follow when I setup a holley 600 double pumper for blowthrough:
http://www.hangar18fabrication.com/blowthru
Also, the Carb + Boost forum at Turbomustangs has a lot of info about this:
http://www.turbomustangs.com/smf/index.php?board=13.0
Reply 0
Dec 1, 2005 | 02:38 PM
thanks for the links. i have checked them out and learned a lot. they say something about sealing the throttle shafts. do you know if the proform base might be okay for this or does it need different seals. thanks
Reply 0
Dec 1, 2005 | 06:50 PM
What do you guys plan to use to up the fuel pressure to the carb under boost?
Reply 0
Dec 1, 2005 | 10:30 PM
I am not sure. Someone told me there was an AFPR that had a vacuum to it to register boost pressure and would add fuel pressure to compensate. I have not found it yet. Still looking. If someone knows please help. Thanks
Reply 0
Dec 1, 2005 | 10:33 PM
The Mallory 4309 has a reference port.
Reply 0
Dec 1, 2005 | 10:59 PM
It has a refernce for boost. I will have to check it out. Have you used one or know someone that has. I would like to know how good it works. Thanks
Reply 0
Dec 7, 2005 | 08:41 AM
To up the fuel pressure, I plan on getting a Carter Strip Mech. fuel pump and running a boost reference to it like they did here:
http://www.turbomustangs.com/smf/ind...?topic=25144.0
Reply 0
Subscribe
