TPI to carb,Pro comp distributor
Subscribe
Sep 6, 2009 | 06:14 PM
Doing a swap to carb,Question 1.anyone running a procomp distributor off e bay?if so are they junk or worth the $55.00?
2.On a 350 ci with 350 to 375 crank hp would a msd ignition be a waste?is a recurved stock hei good enough?motor will see 6000rpm's top.
Reply 0
Sep 6, 2009 | 07:08 PM
Re: TPI to carb,Pro comp distributor
im running one. been running it for a while with no issues.
Reply 0
Sep 6, 2009 | 09:14 PM
1. I have a ProComp as well and can attest that the actual billet housing is pretty nice. The electronics may be questionable, I have had some gremlins with mine. May be attributed to the dizzy itself or to other electronic problems with the car, that I cannot say for sure. For $55 its worth a chance
2. Stock HEI should be adequate although a MSD box is always a great upgrade, but not necessary.
Reply 0
Sep 7, 2009 | 07:33 AM
Can a msd box be hooked up to a stock hei dist.?is anything removed from the stock dist. to do so?How about pro comp hei with msd box?Sorry for all the questions,I'm not really up on ignitions.Thanks
Reply 0
Sep 7, 2009 | 01:30 PM
I have the Procomp HEI dizzy off ebay with the clear cap, in addition to looking very cool, especially at night, while running, I haven't had any sort of issues with it. It appears to be a well constructed unit.
Only problem is now that I have a clear cap, I want to keep it that way when the cap eventually needs replaced. Hope I can find one at that time lol
Reply 0
Subscribe
