messed something up on rebuild
Subscribe
Apr 15, 2010 | 04:49 AM
rebuilt carb ran good for 15 min or so then just died. but starts right back up after pumping pedal one or two times then dies after 30 seconds or so. any ideas?
Reply 0
Apr 24, 2010 | 12:52 AM
Re: messed something up on rebuild
which carb? try to be model specific as there are different fixes for different q-jets, holleys, carters.
Reply 0
Apr 24, 2010 | 02:47 AM
its a quadrajet
Reply 0
Apr 24, 2010 | 09:14 AM
check carefully and make sure you used the right base plate and mounting gaskets.usually the kits come w/several and its easy to use wrong one.from what you describe sounds like all was fine until it came off choke.suspect vac leak from wrong gasket.
Reply 0
Apr 24, 2010 | 02:56 PM
now its runs pretty good after messing with choke but now it runs rich (blue smoke) that wasnt there before.
Reply 0
Subscribe
