I have a 89 rs I installed a carbed 355 but my fuel pump will not work. I have gathered from other posts I need to direct wire the fuel pump, but from where, the relay or directly to the pump??
i have an 89 rs and carbed it and my relay is slightly to the right of my brake booster under the hood i hooked mine up straight from the relay i did this about a year ago so im not exactly sure but i think if you find the fuel relay youlle see a orange wire that tied into your oil sending unit i took that wire and hooked it straight to my fuse box to come on when i crank my car i hope that helps man
92 camaro 25th anniversarry polo green with 2 gold stripes
89 camaro
89 camaro
