carb is spitting fire and gas help please
Subscribe
Feb 19, 2001 | 07:01 PM
edelbrock 600 likes to start on fire someone help please it also pops when letting the engine rev down or when i rev it way up
Reply 0
Feb 19, 2001 | 07:03 PM
time for compression check to see if you have a cracked or bent valve. Also double check your timing and inside the distributor cap.
ODB
Reply 0
Feb 19, 2001 | 07:07 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by mean 355 83 Z28:
edelbrock 600 likes to start on fire someone help please it also pops when letting the engine rev down or when i rev it way up</font>
i did the valves myself and i didnt know exactly what i was doin also the timing is off cause i go by sound and throttle responce
Reply 0
Feb 19, 2001 | 09:15 PM
How did you adjust your rockers? if you went too tight that could also cause this problem because the valves would not close.
Reply 0
Feb 20, 2001 | 12:04 AM
Also make sure the distributor is not off if it was removed.
Chris T's Website
1989 Trans Am GTA
2 1986 Grand Prixs
Reply 0
Feb 20, 2001 | 10:22 AM
Sounds like you put you HEI back in 180 degrees off. I bet it doesn't even start... If it does, then you are a tooth off and running super advanced (like 15-20 degrees base advance).
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Reply 0
Subscribe
