Help with New Holley 0-80508S
Subscribe
Mar 28, 2001 | 09:40 PM
I Bought a new holley for my zz430 And I cant find a way to get fuel to it. IT came with a Line to connect the two float bowls. The end of the line Is female threaded for a fitting. They are shallow threads and have a place for a O ring. I cant find a fitting that will thread into it. I called summit they sent me a 6 An fitting but it dosent fit, I called them again to get a New fuel line that Had a 3/8 hose barb on the end of it so I wouldent even have to use a fitting but they sent me the wrong line 8 21/32 not 9 5/16. I called them again to get a different line and they said they dont have one. Any Info would be great
Reply 0
Mar 29, 2001 | 02:25 AM
I have seen fuel rails for Holley carbs at autozone. Sometimes your in a tough situation and you need to buy from a not so good parts store.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,kickdown kit and tranny oil cooler. Will install 3.73's later on and might go with a more aggresive cam.
Reply 0
Mar 30, 2001 | 05:44 PM
If you look in Jegs (although I wouldn't doubt that Advance might carry them) they have an adapter that will thread into where the swivel fitting used to thread in thr carb and allow you to attach your fuel line on the opposite side
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Reply 0
Mar 31, 2001 | 10:31 PM
Found it Thanks
Reply 0
Subscribe
