1986 ASC weather seal
Subscribe
May 29, 2013 | 05:31 AM
Guys,
I'm restoring my 86 ASC convertible, and my tonneau cover doesn't have the regular seal that some do. Instead of the piece that attaches to the cover itself, mine has a seal that attaches to the body similar to the trunk weather seal. Any ideas what that strip came off of, or where to get it? I compared it to the trunk seal, and they aren't the same.
Thanks.
Reply 0
May 29, 2013 | 09:23 AM
Re: 1986 ASC weather seal
Any pix of the seal your talking about?
Reply 0
May 29, 2013 | 10:08 AM
Ill have to take a photo later this afternoon, but basically, if you can imagine what it looks like with the trunk seal removed.. That's what it looks like when my tonneau seal is removed. A rail is a good way to describe it.
Reply 0
May 29, 2013 | 02:13 PM
I would not be surprised if it was not the same seal as the normal hatch seal, just trimmed to fit... I thought my 89's seal was on the body, not the cover... I will have to look when I get a chance.
John
Reply 0
May 29, 2013 | 06:34 PM
Quote: I would not be surprised if it was not the same seal as the normal hatch seal, just trimmed to fit... I thought my 89's seal was on the body, not the cover... I will have to look when I get a chance.
John
Here are some photos.
Reply 0
May 29, 2013 | 06:37 PM
More
Reply 0
May 29, 2013 | 06:39 PM
Quote: More
One more of the rail without the trim. Sorry for the multiple post.
Reply 0
May 29, 2013 | 10:19 PM
That looks like the hatch seal, its just folded a bit different due to being sealed/closed and time..
Reply 0
May 29, 2013 | 11:21 PM
They probably hadn't worked out the kinks of the weatherstripping the things at that time so it's probably year specific. I know in 89 the weatherstrip isn't the same but it's also nowhere near perfect. I have had to adjust the tonneau cover weatherstrip several times. It gets stuck in between the tonneau and trunk. While not correct for your year I would just update to later year weatherstripping.
Reply 0
May 30, 2013 | 04:39 AM
I wouldn't mind changing to a later year, but I don't see how mine would seal, with what's available. I'm seeing the one that attatches to the tonnaue cover itself, but how would that seal to my body. Can I get a photo of what a body looks like where the seal is supposed to sit beyond my 86 from someone?
Reply 0
May 30, 2013 | 07:00 AM
You can use the newer seal if you use something like this on your pinch weld. That's what is used on my 89 and 92 verts.
http://www.ebay.com/itm/Black-Windlace-pinchweld-push-on-snap-on-molding-trim-free-shipping-/200793910270?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2ec03febfe
Reply 0
May 30, 2013 | 08:59 AM
Perfect. Any idea as to how many feet I need to order? Thanks again!
Reply 0
May 30, 2013 | 09:34 AM
Quote: Perfect. Any idea as to how many feet I need to order? Thanks again!
I'm not 100% sure the link I gave you is the correct size you need. Its more of a idea of what your looking for so don't order that unless you know 100% for sure.
As far as how much you'll need, since your car is apart, maybe, measure the length of your pinch weld you need to cover?
Reply 0
May 30, 2013 | 11:50 AM
Ok, I'll check it out when I get home. I was just trying to get it ordered early today... Wasn't being lazy :-)
Thanks again!
Reply 0
May 30, 2013 | 12:45 PM
Quote: Ok, I'll check it out when I get home. I was just trying to get it ordered early today... Wasn't being lazy :-)
Thanks again!
Oh, not a problem at all. I'd like to give ya the measurement buuut I couldn't till later
Reply 0
May 30, 2013 | 01:02 PM
I would take a tape measure and wrap it around the area you need... Add 1ft for good measure and then trim to fit when you get it.
When installing, I would not "pull" or stretch the seal, as it will want to shrink or contract. I would make sure it is tight fitting, as making it shorter is easier than making it longer.
John
Reply 0
May 31, 2013 | 08:11 PM
I've ordered it twice from my upholstery place. . 3 yards was too short, 5 yards was too much. I can't remember in feet how much it was short or long though...
Kevin D.
Reply 0
Jun 8, 2013 | 07:41 PM
I just got my trunk seal in the mail today, and its pretty much the same as the seal for my tonneau cover, so I'm about to order a second one. Thanks for all the help and suggestions.
Reply 0
Subscribe
