Hayden 3800 Dual Fans
Subscribe
Feb 8, 2004 | 04:43 PM
ok I baught a 85 camaro on Dec. 12th It has One Ecectric Fan. The guy I baught it off of wired the fan To the Ignition On when the engine is running the fan is constantly on. This isn't letting the engine get hot enough to reach Closed Loop Mode, So I am looking into using a Hayden 3800
The Question is I think It will mount up with out any Clearence Problems , but the factory fan switch is still there but the orange wire is going directly to the battery so when the engine is on the fan is on and I don't think it should be (correct me if I am wrong)
But I will buy two Hayden temp switches a #3652 that will turn One of the fans on at 185F and off at 170F It will be wired linke in this Fan control article.https://www.thirdgen.org/newdesign/tech/cool8dual.pdf
The second fan will be hooked up to a Hayden #3647 Temp switch but not sure what temp I shoud set it at I think maybe about 210F. Any Suggestions or if this will fit ok.
Anyone with info of a website that I can Buy Hayden Fans or a store let me know I have yet to find one.
Reply 0
Subscribe
