Thermostat Housing issue...
Subscribe
Sep 4, 2010 | 06:19 PM
Broke the rear stud/bolt thing off the rear of the thermostat housing and drilled and tapped it...metal shavings fell into that bolt hole while working...it that anything i should be worried about or is it sealed from everything else...thanks
Reply 0
Sep 4, 2010 | 07:13 PM
Re: Thermostat Housing issue...
I'd think there should just be metal shavings in the coolant - might cause a blockage in the radiator but that would be the smallest passage area so that would be the only place.
Reply 0
Sep 4, 2010 | 11:37 PM
i think you are okay its just a bolt hole and no coolant leaks from the bolts. put antiseize on the bolts just in case it leaks again and the bolts rust.
Reply 0
Subscribe
