My kiddo and I just picked up an 87 Camaro that was a V6 - 700r4 car that has been converted to a 350-350. There is no compressor, brackets, or hoses for the A/C. Does anyone make the box for a heater only so that we can go ahead and remove the evaporator and dryer or will this cover have to be made? Thanks for any info !!
NoEmissions84TA
close
- Join DateFeb 2017
- LocationMeriden, CT 06451
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car84 TA orig. 305 LG4 "H" E4ME
- Engine334 SBC - stroked 305 M4ME Q-Jet
- Transmissionupgraded 700R4 3200 stall
- Axle/Gears10bolt 4.10 Posi w Lakewood TA Bars
- Liked:576 Times in 476 Posts
Is the blower motor still there, and was it an AC car?
If so, then this will do the job: https://www.ebay.com/itm/AC-Delete-C...gAAOxyyghQ6fur
There are less expensive boxes available, but this one is specifically made to retain using your factory AC blower motor and fan.
Quote:
If so, then this will do the job: https://www.ebay.com/itm/AC-Delete-Cover-Heater-Core-box-for-1982-1992-Camaro-Firebird-AC-Delete-Box/324186703277?hash=item4b7b0885ad:g
KgAAOxyyghQ6fur
That is exactly what I was looking for !! Factory A/C blower is still there. ThanksOriginally Posted by NoEmissions84TA
Is the blower motor still there, and was it an AC car?If so, then this will do the job: https://www.ebay.com/itm/AC-Delete-Cover-Heater-Core-box-for-1982-1992-Camaro-Firebird-AC-Delete-Box/324186703277?hash=item4b7b0885ad:g
KgAAOxyyghQ6furThere are less expensive boxes available, but this one is specifically made to retain using your factory AC blower motor and fan.
I have everything you need still in great conditon. I just removed all the stock hvac from my 86 camaro it works great im just going with a vintage air setup
Quote:
We already have the A/C delete box coming. Not gonna mess with trying to put the A/C back. It will be driven some on the streets but will probably spend most of its time at the drag strip so no real need for a working A/C for now !!Originally Posted by MrOwens87
