Does anyone know where the "convenience center" is on a 1989 IROC convertible 5ltr?
Also managed to get the car started today, albeit, we had to by-pass the relay switch to the pump. It appears we are not getting 12 volts to that switch. The wiring diagram shows there is an inline fuse (20amps) in the wire leading to the relay. We have not managed to find this particular inline fuse. Do you have any idea where it might be located?
Thanks,
Chris
Thanks,
Chris
For the convenience center location, key in the ignition and open the drivers door. Follow the sound of the chime. I believe that it is under the dash on the drivers side.
Inline fuse is around the battery. Or along the passenger side fender well near the front. Typically that fuse also feeds the ECM. So it should be OK. But never hurts to check it.
RBob.
RBob.
Tags 89, 92, camaro, center, conevenience, convenience, convinience, diagram, ecm, fuse, fuses, generation, inline, location, wiring
