91 Formula Check engine light after 60mph
Subscribe
Sep 22, 2022 | 09:37 PM
Hello. I have a 91 Firebird Formula that I just had the egr deleted on. Since getting back from the garage it gets a check engine light once I drive at highway speed, and then it will idle hunt in park and neutral. It will return to normal if you shut the car off for a second. It won’t happen if you don’t hit that speed and cause the light to come on.
the codes I’m getting from the scanner are unreliable and always different every time I check. I pulled both terminals off the battery for 2 hours and there was codes on it before I even started the engine for first time. However vehicle speed sensor was a prominent code being shown, so I replaced the speed sensor and still no change.
1991 5.7 tpi. 60k miles. Had injectors and distributor changed when I had egr deleted.
Some of my dumb guesses now are; bad computer? Egr delete causing it? Any more speed sensor related parts to change?
Any advice appreciated!
Reply 0
Sep 22, 2022 | 09:42 PM
Re: 91 Formula Check engine light after 60mph
Have you blinked the codes , sounds like a code 32
Reply 0
Sep 22, 2022 | 09:51 PM
Quote: Have you blinked the codes , sounds like a code 32
I haven’t done the blinks. Figured a code reader would tell me what it knows.
so based on code 32 you think it’s a map sensor, or egr?
Reply 0
Sep 22, 2022 | 10:00 PM
Egr more than likely
Reply 0
Subscribe
