Nope, the VSS signal goes through the dash for display, and into the ECM as an input to control other parameters like TCC. If you're angling toward whether a gear change will require speedo/VSS/tranny changeup, the answer is yes.
I actually am preparing to swap my 87 lg4 to a 85 tpi.My full post is down this page a little bit if you could check it out.
