ATTN Grumpy: Could you take a look at this?
Subscribe
Jan 13, 2001 | 04:59 PM
Here is the website of someone who built an oscillator to defeat the Passkey system:
http://home.hiwaay.net/~davida1/passkey.htm
Does this look like something that would work on my system? On what circuit are the oscillations emitted? It looks like the 1986-1987 'vette setup used terminal B6 with the dark blue wire. Do I simply run the oscillator with a 5 volt output at approximately 50hz to this terminal? Thanks.
Reply 0
Jan 13, 2001 | 05:33 PM
Do ALLL THAT when all u have to do is click a checkbox in TunerCat to disable VATS, then burn the bin on a chip. LOL
Reply 0
Jan 14, 2001 | 09:59 AM
Hmm, thought it was 5v specific, but he's using Bat., so I guess that will work.
Don't have vette diagram handy, but what ever the vats feed to is what you use.
Reply 0
Jan 14, 2001 | 01:55 PM
Might it be better for me to reduce this voltage to 5V, or would that be of any benefit at all to the system if the signal is not voltage specific? How could I wire the 7805 regulator to supply the device without affecting the frequency of the oscillations? Thanks for your help.
Reply 0
Subscribe
