Decel A/F ratio too high
Subscribe
Jun 7, 2009 | 07:30 PM
Ok here's a new problem I encountered last night while cruising the street scene. I noticed when I let off the throttle the A/F ratio stays around 12.6 until my speed drops below 50mph and then the A/F goes back to normal. Anybody have any idea why it's doing this?
Reply 0
Jun 7, 2009 | 09:07 PM
Re: Decel A/F ratio too high
Correction - I should rename this thread "Decel A/F too low" instead of too high. Any help is greatly appreciated.
Reply 0
Jun 9, 2009 | 09:19 PM
I take it I'm the only one with this problem? I still haven't figured it out yet.
Reply 0
Jun 10, 2009 | 07:43 AM
Are you running large injectors? I have 4 x 85lb injectors (same as 8 x 42lb) and on hard decel, it's at the min pulsewidth and can't run any leaner than ~12:1. But, fortunately, I have the option to cut off fuel completely on decel to help save fuel.
Reply 0
Jun 10, 2009 | 09:10 AM
Quote: Are you running large injectors? I have 4 x 85lb injectors (same as 8 x 42lb) and on hard decel, it's at the min pulsewidth and can't run any leaner than ~12:1. But, fortunately, I have the option to cut off fuel completely on decel to help save fuel.
I'm running 30lb injectors. Constant is set at 33lbs
Reply 0
Jun 11, 2009 | 01:59 AM
Decel Enlean Vs differential MAP
Decel Enlean vs differential TPS
Reply 0
Jun 11, 2009 | 08:19 AM
Does anyone know the S_AUJP v4 translation to these 2 tables?
Reply 0
Subscribe
