Hi Guys - a little over my head here as regards Hex Code etc so I'll explain best I can here...
I'm looking to use PE Spark Advance to RETARD timing (Boost). I obviously would need to put negative numbers in the PE Spark Advance vs RPM Table.
Following conversations with junkcltr he beleives it to be possible if the XDF for TunerPro was given the correct equasion.
Quote:
Originally Posted by junkcltr
It is a problem with your definition file (XDF, TDF, etc) for the software you are using to do the edits. Post in the DIY PROM that you are looking for the correct equation or file so that you can put negative numbers in the PE spark. The definition needs to save it as a 2's complement number (neg number). Instead of saving it properly, they are putting in a zero. Moderator
It won't work unless the code is modified.Originally Posted by dan_t
Hi Guys - a little over my head here as regards Hex Code etc so I'll explain best I can here...I'm looking to use PE Spark Advance to RETARD timing (Boost). I obviously would need to put negative numbers in the PE Spark Advance vs RPM Table.
RBob.
