i have an 86 Z w/ 145 speedo(not sure if that means anything), anyway about two weeks ago the instrument light fuse blew. it looked like it was an OEM fuse so i thought no big deal. Replaced the fuse, and about a week later, it does it again! i replace the fuse again, last night it blows again. Im out of 5w fuses and its dark, so i grab a 10w and throw it in there. Still nothing. I try again with a 15, still nothing. The instrument lights dont seem to be working at all now. Could it just be that the circuit will not work w/o a 5w fuse? Also, does anyone have any clue why the fuse keeps blowing? The only thing that had been done to the fuse box in the last 3 months is tapping into a power lead for my stereo. Does anyone have any clue as to whats going on here?
EDIT: i just thought of something else that might be helpful. my T-yops leak like crazy in the rain. Could the water have shorted something out? It was dry out when the fues blew.
My 1986 Z28 and more!!
Also, the proud new owner of an 85' IROC with 1364 miles!!!
R.I.P Dale Earnhardt
[This message has been edited by zupmanZ28 (edited March 05, 2001).]
If your stereo is connected to the dash light circuit, try disconnecting it from the fuse panel & see if the short goes away. If not, the short is in the dash light circuit, after the fuse & you will have to isolate the short using an ohm meter. Did you add any lighted gauges?
Tim
Tim
I had a simmilar problem turned out to be the cigarette lighter. Worth a try to just pull it out and see.
I had the problem with the cigareete lighter too.
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Double-Pump This! EFI Rules!
Definition:
NOPI: n. 1. import 2. Sticker worth 47 hp 3. import with 6" exhaust tip
antonym: smallblock
Definition:
antonym: smallblock
yep you guys are right, it was my cigarette lighter. I knew i had taken it out for some reason, but i couldn't remember so i put it back in. Does anyone know why this does this and how to fix the problem?
