ok so I go to a yard and rip out 2 motors, take them home and the wireing harness doesn't match, the motor in my car has 2 wires, but the motors I bought have 3 wires, can I make them work, help please.
neko
'87 trans am
car in the making
angelfire.com/fl2/neko
neko
'87 trans am
car in the making
anyone? both cars were equiped with modulators if that helps, my car has the small motors that suck, and the ones I got are the better(in my opinion) bigger ones, they are both 87 trans ams, why does mine only have 2 wires instead of three, help
neko
'87 trans am
car in the making
neko
'87 trans am
car in the making
You got the motors out of an 86-earlier model,,, They can work,, but I don't think you want to go thru the trouble of trying that.
The 86-earlier had the module similar to 87 & up but, each light motor(86-earlier) had a seperate relay (fiero's motors are the same) to actuate it thus, the 3 wires. I'd draw you a diagram to go with the other I did so you could compare but(I'm not), it's too late & I'm doing good to see right now
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
[This message has been edited by deadbird (edited November 29, 2001).]
so I need a relay for each motor or can I just leave the third wire unplugged.
neko
'87 trans am
car in the making
neko
'87 trans am
car in the making
thanks for the advise but someone came up with a better idea then wiring up relays. someone on the third gen mailing list told me all I have to do is wire the 2 hot wires together, so I did. the two power wires go into the one side of the power connector and the ground into the other. I did it and it works perfect. great up and down action. thanks for all the help.
neko
'87 trans am
car in the making
neko
'87 trans am
car in the making
