I need help determining which one of these is my fuel pump relay. i've got a 1987 Camaro RS 2.8l v6 (poop), but this car has been sitting for some time and i've been recently working on it trying to get it to run, but the fuel pump just wont turn on and pump gas. so im trying to see if its the relay. any advice would be helpful.[IMG]file:///C:/Documents%20and%20Settings/Owner.COREE/My%20Documents/My%20Pictures/Picture/Picture%20087.jpg[/IMG]
The fuel pump relay should have an orange, black, green, and a grey wire. If i rememeber correctly its the one attached to the bracket beside the one that says made in china in your pic. But if the car has been setting for a while there is a very good chance that the fuel pump is junk.
i have already dropped the tank and replaced the fuel pump with a new strainer and fuel filter. and your sure the bracket that says made in china is the fuel pump relay? because i plan on changing it for a new one.
Bobby_80s
close
- Join DateNov 2006
- LocationConnecticut
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car1987 Camaro, 1986 Trans AM
- EngineV6 2.8 multi-port and V8 5.0 FI
- Transmission5-Speed and Automatic
- Axle/Gearsno idea
- Liked:0 Times in 0 Posts
go on tpiparts.net. they sell new relays and even wiring connectors. either call and ask what color wires should be connecting to your fuel relay or go through their catalog onlien and find the connector and match the colors yourself.
