9 bolt brakes modified for 9" rear
Subscribe
Oct 21, 2006 | 02:52 PM
iron calipers, remans from autozone with lifetime warranty.
top of the line autozone pads in decent shape if you really want them.
caliper line fittings have 3an fittings brazed on to accept braided or AN hard line.
backing plates have been drilled to fit on big ford pattern, and drilled for 3.150 axle bearings.
i believe the e brake hardware is gone. im not sure where i put it.
i ordered my 9" to work with these brakes, and its my understanding they put the housing ends on horizontally for these brakes instead of the standard vertical postion(for aftermarket discs, or ford drums)
i just hate to throw the stuff away. i know the calipers are worth a lil and the backing plates can be salvaged if you run a 3.150 bearing. you can always drill new holes to fit your axle tube flange.
MAKE offer. only thing thats gonna hurt is shipping.
rather heavy.
Reply 0
Subscribe
