1. 8 rib supercharger pulleys $35 ea.
2. Billet aluminum fuel filter with mount and check valve (new) $75
3. Polished aluminum water neck $20
4. Bosch bypass valve for blower $50
5. Comp Cams Custom ground hydraulic roller cam (.544 I .556 E 230 I 236E 114 lope separation) $250
6. M112 supercharger, intake and fuel rails built for a sbc and fits under stock camaro hood $1000
All parts except the fuel filter are new
Pictures available on request
What would you like pics of? If you need more than 1 pic please pm me with your email address and I will send them to you.
Everything related to the blower setup, and is there anything else needed to install on a sbc? If so, what?
Tim
Tim
[URL="https://www.thirdgen.org/forums/power-adder/420580-cheap-supercharger.html"]
Here is a link to another post with an old picture of the blower. I am selling the blower, intake, fuelrails, fittings, intake bolts, bypass valve. I have the the design for the pulleys complete and blower mounting plate but I no longer have a motor to install the parts on to check if they are correct. I will include the material I have for the pulleys and blower mount. I could finish the blower mounting bracket if I new what pulley you would be using. You will need to fabricate the intake plenum from the back of the blower to the stock tpi throttlebody.
