10 bolt posi rear 2.73 gears
Subscribe
Jan 23, 2010 | 09:29 AM
Rear is in good working order. Posi works good. Gears are in good shape. No uneven wear pattern. Gear ratio is 2.73. Comes complete drum to drum w/ e-brake cables, rear sway bar and pan hard bar. $100 firm
Trying to clear out space in garage. Great deal !!!!
located in Hatboro,Pa
Reply 0
Feb 16, 2010 | 07:05 PM
Re: 10 bolt posi rear 2.73 gears
Do you know what the axle identification number is?? it is stamped on the front of the right axle tube about 3 inches from the differential (under rust and grime).
Thankis, Jon
Reply 0
Feb 16, 2010 | 07:16 PM
The posi unit has been sold and I throw out the housing and axles. I only have the drums,shoes and hardware left.
Reply 0
Subscribe
