Sep 27, 2010 | 02:49 PM
sbc edelbrock airgap brand new-----175$
nitrous cheater plate used on my speed demon-------60$
speed demon 750 mechanical-------240$
world product torquer heads-----500$
autometer liquid filled fuel psi(sport comp)-----50$
b&m trans cooler with brand new steel braded lines and 6an fittings---------75$
th350 short shaft--------150$
350 2 bolt block-------75$
stock 350 crank 2 pc seal rods and trw pistons with 15k----50$
brand new double roller timming chain------75$
im selling the maro so no need for the parts i don't wanna deal with shipping on the stuff local pick up only please location is mchenry il. any questions email 2001z71@gmail.com thanks
Reply 0
Sep 27, 2010 | 08:26 PM
Re: sbc lot
does FP guage have all wiring and sensor/pick up .Will you do 50 shipped
Reply 0
Sep 27, 2010 | 10:36 PM
Re: sbc lot
Quote: .Will you do 50 shipped
Seller states above
"i don't wanna deal with shipping on the stuff local pick up only please "
Reply 0
Sep 27, 2010 | 10:47 PM
Re: sbc lot
Quote: b&m trans cooler with brand new steel braded lines and 6an fittings---------75$
IS the block a Hydraulic roller with the spider still?
I know you dont want to ship but If you could how much for all this to 78380 business address?
Reply 0
Sep 28, 2010 | 07:52 AM
Re: sbc lot
what are the specs on those heads? part number/intake ports/valve size?
Reply 0
Sep 28, 2010 | 09:21 AM
Re: sbc lot
im unsure of the block being a roller and it does not have the spider its just bare block. stylin the heads are the s/r torquer
Casting ID Number: I-052, I-058
Material: High density cast iron
Valve Seats: Intake (integral), exhaust (hardened)
Valve Guides: Integral cast iron
Spring Seats: Machined for 1.560" and 1.250"
Valves: Manley stainless steel valves in assemblies (inconel exhaust valves on marine applications)
Valve Diameter: 2.020" intake, 1.600" exhaust (11/32" stem)
Rocker Arm Studs: Screw-in style
Rocker Arms: 1.5 ratio (use of 1.6 ratio will require elongation of pushrod holes)
Intake Runner: 170cc, standard port location
Exhaust Ports: 65cc, standard location
Combustion Chamber: 58cc, 67cc or 76cc, straight plug orientation
Spark Plug: 14mm 5/8" .460" reach tapered style
Valve Job: Multi-angle intake and radiused exhaust
Valve Cover Rail: Raised w/ perimeter and center bolt pattern
Valve Angle: Stock 23°
Accessory Bolt Holes: Stock
50-State Emissions legal
Accepted by most oval tracks and sanctions as stock replacements. Check with rule book.
Spring Specs
1.250": 100 lbs. @ 1.810", 300 lbs. @ 1.250", coil bind @ 1.200", max lift @ .560"
1.437": 125 lbs. @ 1.810", 340 lbs. @ 1.210", coil bind @ 1.160", max lift @ .560"
Head Flow @ .500 Lift
220 intake, 151 exhaust (Super Flow 1050)
232 intake, 161 exhaust (Super Flow 600)
All heads flowed with a standard .750" intake plate, without exhaust tube, and 28" of water
Reply 0
Sep 28, 2010 | 11:25 AM
Re: sbc lot
stroked92
if fuel pressure guage is complete and electric ,would you consider shipping for 15.00 extra to 80915
I thought this was stroked92's thread . I made an offer to stroked 92 , not to vetteoz . As others have ASKED, i OFFERED HIM a purchase with ship if he changes his mind . vetteoz ,why are you responding to my offer ? It was not to you .
Reply 0
Subscribe
