ford 9 inch drag rear end 82-02 f-body make offer Decatur AL
Subscribe
Nov 1, 2010 | 06:45 PM
this a moser housing ford for 9 inch rear end i believe its 4-11 gears but not sure, with the main chunk included for a 82-02 camaro or trans am/firebird with the disk brake setup included. It would be great in a drag car these things are almost impossable to break, it whines pretty bad when letting off gas (from space between the gears I think) but works great when your on it it might not even whine if it was resetup making it much more suitable for the street, I know that if you were to build one it would run you 2500-3000 bucks. make me a reasonable offer but im not going to give it away so keep that in mind before you call 256-466-3617.
It came out of a 95 z-28
Also I might trade for something cool let me know what you have
Reply 0
Nov 1, 2010 | 06:56 PM
Re: ford 9 inch drag rear end 82-02 f-body make offer Decatur AL
What is the track width? '95 F-body's have wider rear axles than '82-'92 F-body's. It's not necessarily a drop in replacement.
Reply 0
Nov 1, 2010 | 07:04 PM
its a direct bolt in replacement plus the extra 2+ inches each tire on a thrid gen not sure on the exact measurments its the same as a stock fourth gen rear whatever that is
Reply 0
Nov 6, 2010 | 10:14 PM
pm sent
Reply 0
Subscribe
