Accel 74202S3 4 barrel (well, 3 technically) 1350 cfm 4150 flange series throttle body. I also have a modified 2 or 3" drop base filter housing designed to clear the throttle pull linkage. $285 shipped.
I'm interested. What linkage/cable did you use? Do you know the part numbers of the sensors? PM sent
Do you know if the TPS and IAC will plug directly into the stock TPI wiring harness or did you use an aftermarket computer and harness?
The TPS will plug directly into your harness and the IAC requires Accel 77651 harness adapter for $24. I know I had one, but I think it went with the DFI harness I sold.
Thanks. So all I would need to do is mount the manifold air temp sensor in the cleaner and I can use the stock wiring and computer. I'll let you know if I decide to switch from my Mini Ram.
I used the Victor E EFI single plane manifold which has a provision built into the manifold for the air temp sensor.
