While working under the car today, I discovered that the previous owner stripped the bolt that holds the shift cable to the gear selector on my 700R4. It's been held on with a cable tie since I bought the car last February. Does anyone have the correct bolt and nut for this that they would like to sell?
TIMMYS89GTA
close
Quote:
I just put a brand new cable from advance auto in my car and the cable had the bolt that connects to the linkage already installed onto it.Originally Posted by vette gator
While working under the car today, I discovered that the previous owner stripped the bolt that holds the shift cable to the gear selector on my 700R4. It's been held on with a cable tie since I bought the car last February. Does anyone have the correct bolt and nut for this that they would like to sell? I don't know what you mean by zip ties holding it on,maybe your car is missing the clip that supports the cable to the back side of the shift cable bracket thats connected to the trans pan?
Anyway,if you need a clip,buy the doorlock clip set at the autoparts store.
It is located in the help section and if you need the bolt only,you can have the one from my broken shifter cable.I see you're in G'ville,so not really that far from me.
I should have taken a picture while I had the car up on stands. It looks like all the pieces are there, but I have a cable tie in parallel with the bolt since the nut can't be tightened up. If you have a spare bolt and nut, that would be great.Originally Posted by TIMMYS89GTA
I don't know what you mean by zip ties holding it on,maybe your car is missing the clip that supports the cable to the back side of the shift cable bracket thats connected to the trans pan?Anyway,if you need a clip,buy the doorlock clip set at the autoparts store.
TIMMYS89GTA
close
Quote:
yeah man,like I said I just replaced a broken cable in my car so,I def. have a spare one.I'm gonna be at the turkey run in daytona tommorow so,don't know when a good time for you to come get it would be.I work mon-fri at I-75 and hwy.326 a bit closer to you than ocklawaha!lolOriginally Posted by vette gator
I should have taken a picture while I had the car up on stands. It looks like all the pieces are there, but I have a cable tie in parallel with the bolt since the nut can't be tightened up. If you have a spare bolt and nut, that would be great. I can bring it with me to work if you want to come get it.I bought the new cable for $29 and came with the bolt so,let me know if you want it.
