Z28 Lower Fan Support + Wide Upper Rad mount panel
Subscribe
May 5, 2011 | 11:45 PM
I need a couple pieces for my car. This is a reply i got from the cooling section. Anyone have these?
"yep,looks like you are missing the lower fan support and
have the narrower upper radiator support-get the fan
bracket and a wider upper radiator support panel from a
single electric fan v8 car or possibly a later v6 as i think
the later v6s have the wider upper radiator mount panel
too.The fan itself is the same between the v6 and v8."
Reply 0
May 6, 2011 | 11:18 AM
Re: Z28 Lower Fan Support + Wide Upper Rad mount panel
I've got the upper piece in great shape with fan bolts included and maybe bottom one. Get me your email address for pics and other info. I assume you have parts of or are putting in a single fan system? What do you have now? And what engine/car? I probably have several fan parts
Reply 0
May 6, 2011 | 01:14 PM
I'm at work at the moment, check my thread in the cooling section. Thanks
Reply 0
May 6, 2011 | 01:39 PM
Right, I've got the top piece, has the hose support on the driver side. I sent one before, takes a good size box. I'll look for one and see if I still have a bottom piece as well unless you just want this top part fast. LMK, Henry
Email address if you want pics
Reply 0
May 7, 2011 | 03:53 PM
I found the other piece too with mounting bolts, do you still want these? Both in solid undamaged state, no cracks or weak points, good as new. LMK, Henry
Reply 0
May 8, 2011 | 05:14 PM
How much for the wide upper rad mount panel as well as the lower panel?
Also, do you have any TPI injector harness clips laying around? im short a few. Its the little spring that goes over the injector plug on a TPI harness.
Reply 0
May 9, 2011 | 11:03 AM
PM sent yesterday
Reply 0
Subscribe
