ok i recently bought a dynomax cat back and i tholught a high flow catco converter would be a nice touch to my set up. Now heres the deal, the intermediate pipe (near the converter) is an oval port. The converter (catco) is also an oval port, but the problem is its an oval port on the other end too (near y pipe). Whats up with that?? my y pipe doesnt have an oval port nor does it have a flange (like converter does on both sides), please tell me there is an adapeter that will allow this to bolt up to my y pipe.......
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
Well the stock exhaust on my 1985 305 TPI Z-28 has the oval flanges. The CAT has four bolt flanges on both sides of the CAT.
hmmm.
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
hmmm.
James
1985 Z-28 305 TPI
I don't know for sure, but if you ordered the universal, I heard that it needed to be welded as oppsed to the direct replacement which can bolt up but is like twice as much.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
90 IROC 5.7l (L98)
LIKE A ROC
Sounds like you ordered the correct cat for your car, but it sounds like you don't have the original y-pipe on your car for some reason. It is my understanding the stock 85 setup has bolt on flanges on both ends of the cat... From your description I'm not sure if they're going to have a cat that is going to fit correctly, you'll probably end up just getting a universal cat w/ slip fit on both sides and having an exhaust shop get everything attached and welded up correctly...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
well the y pipe on the car isnt origional. Its from an 86 trans am. I ordered a new y pipe and i hope to god this will be my problem. Its odd i never heard of a y pipe with an oval 4 bolt flange.
