do I need these things this long or can i cut them?
You should be able to cut them off. My Hookers have the flush with the header tubes inside.
Yeah, they can be ground down to make them flush with the tubing. Some will even say you will get better flow with them ground down.
Quote:
Ok, shouldn't be a problem with my nearly stock engine.
Thanks for the replies
