Dual Snorkel Aircleaner I NEED help
Subscribe
Feb 16, 2012 | 12:04 PM
Does any one know where I can find the hose that attaches to the single end of the Y intake that drafts air through the grille? I don't know how else to explain it but I need this piece. or the plastic passenger side intake that mounts behind the headlights? any input could help because I dont know where to look.
Reply 0
Feb 16, 2012 | 07:06 PM
Re: Dual Snorkel Aircleaner I NEED help
Not sure what part your talking about. Heres a pic of the dual snorkel p/n's.
Havent run them lately. Few years back only the LH or RH hose was available.. You can order two of the same side, since both are the same length. just the little locking clips will be going the same direction., no biggy.
Reply 0
Mar 2, 2012 | 12:13 AM
if your looking for a extenable air intake hose then yes, the place to look would be Spectre Performance. i belive hes looking for the tube that looks simular to RV sewage but the one hes thinking of is used for cold air kits and alows you to snake arround the engine bay.
i have the dual 4" spectre aluminum cold air intake on mine and had the same idea snake it to the two ports in the bumper... Heres the problem... that area is the MAIN air flow to your radiator. so if you plan on puting your air filters there it could cause decrease in air flow and these cars tend to want to get warm sitting at a idle on a hot summers day.
ive got my car stripped now and i plan on taking the trays out where the battery goes and the panel on the opposite side and building a cold air inlet there, i relocated my battery to the pass side rear where the spare use to be. im not done with the mod yet but check my build thread i should have pics in the next couple of weeks.
Reply 0
Mar 2, 2012 | 08:33 AM
Quote: if your looking for a extenable air intake hose then yes, the place to look would be Spectre Performance. i belive hes looking for the tube that looks simular to RV sewage but the one hes thinking of is used for cold air kits and alows you to snake arround the engine bay.
Alright Ill check it out for sure thanks
Reply 0
Subscribe
